can 3G modem work directly on receivers 800hd
Check this thread below gives you a list of the 3g routers that are available for 3g dongles.
Andy.
you need to use a router like the tp-link 3240/3220 i use one and find it as good as ,u just need to make sure you are getting a good signal from the sim dongle so you may be better with an unlocked dongle and try different sims till you get the strongest signal and you are good to goComment
Would you say its as good as normal broadband?you need to use a router like the tp-link 3240/3220 i use one and find it as good as ,u just need to make sure you are getting a good signal from the sim dongle so you may be better with an unlocked dongle and try different sims till you get the strongest signal and you are good to go
What sim did you use??
Cheers
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
The mileage you will get using 3G will vary considerably depending on your location and what other people using the same cell are doing. Generally, the mobile operators tend to allocate only a relatively small amount of bandwidth between ALL users on the cell. This may give you the situation where things apparently work well most of the time but occasionally you get glitching (or nothing at all) whilst somebody else is downloading something large. If a lot of people in your area are using 3G dongles then chances are anything requiring timely response will not function properly !Comment
