i wiped my tuner config setting in 800hd i had 2 sats but went in to tunerconfig and pressed wrong button (no to all) thinking it would take me back and lost alll sats, anyone help pl
tuner config settings
got to:
Menu
Setup
Service Searching
Tuner Config - select tuner
Then you will need to configure your sats
certain bits here will defo help you http://www.digital-kaos.co.uk/forums...-dm800-108809/
if you get stuck post back here -
thanks i went to tuner but it is saying not configured so cant choose it, i know my dish is on hotbird at the mo, is there a way i can get in to config my tuner as i know it will work ok after that, really new at thisComment
try this way mate
menu >set up> ok service searching>ok tuner configuration>ok
then useing left and right buttons set the tuner config mode to
either simply or advanced if your useing the long/lat motor settings
to move the dish then choose simple if you use diseqc 1.2 motor settings
then it's the advanced settingsPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
