Possible ?
  • packmanuk
    • Jun 2011
    • 149
    Possible ?
    Is it possible to send a live sports stream (US Football from NFL.com) from my desktop PC to my dreambox 800hd clone so that I can watch the game on the tv instead of the pc ?
    I think it is possible but hopefully someone can confirm and if so let me know how to set it up (hopefully its not too difficult to do)
  • andiewill
    • Aug 2008
    • 490
    I think it would be easier for you to get a lead for your computer to tv and do it that way.... rgb to hdmi, hdmi to hdmi as an example as i dont think it can be done that way, but im sure i will be corrected if it can..........
    ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
    • dctyper
      • 2539
      no, we discussed this last year. the thinking behind it was;
      i was going to record a live stream on my pc then stream the file to the dreambox like a movie, hpoing for a s slight dely. it didnt work
      dc
      Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
      previous life dm800hd and 500c on cable screw you nag3
      • TheCoder
        • Jun 2011
        • 693
        The major problem is that most of the internet streams are in formats the dreambox doesn't recognise. In order for this to work you require the data to be transcoded into a fairly standard TS datastream. Unfortunately few programs/pc's are capable of doing that in real time.
        If you can arrange to have the transcoding done then its basically just a matter of running a playback program on the dreambox that accepts its input from the network rather than from the sata drive. As long as you can make your stream look acceptable (ie, like its been recorded by the dreambox in the first place) then there shouldn't be a problem.
        • mfaraj57
          • 557
          you can send recorded material in most common formats to dm800 through vlc player and presence vlc player plugin in dreambox
          daily we use this method to explorer harddisk of pc and select any media
