hi all finally got a dm 800se clone but problems i have all channels for around hr or so then all go if i unplug box and router leave for five min it comes back any help advice greatly appreciated ferrari sim bl82ff
help dm 800 se
Please Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
server `seems' good? You sure on that? also the network test does not test the `server' I am talking about..
Also, have you checked your router settings? Have a look in there and see if its kicking it off at any point, might not be refreshing the lease for the dreambox IP, thus it wont connect to the net, thus no channels..Comment
Yeah no problem mate! We all started somewhere.
Get into your router settings, try 192.168.1.254 in your browser. You need to find your home network bit, and see if there is any problems in that area. Could be that your router is disconnecting your dreambox from the net every so often.
When you setup your network on the dreambox, did you use dhcp?Comment
Get Wimax to check out your line...are you having any probs with your connection to pc/laptop whilst the box is on?
Do you have enough bandwidth to supply the dreambox and your home internet usage....are family members downloading while the box is broadcasting?
Whats your internet speed?,theres a multitude of things to check out if your having this problem.
Try answer some of the above and might solve yours.
Freck
Wimax is not the best in Kerry bud
sigpicComment
Is your service from russia & are you using CCcam with a N Line? if so when you flick through 2 many channels they will go off and you'll be banned for 10min to and hour. you need to use MgCamd to solve the problem if thats the case.
If its not from russia PM meLast edited by beats2006; 31 October, 2011, 11:45.Comment
Ive not heard of that with an N: line and cccam before mate?Is your service from russia & are you using CCcam with a N Line? if so when you flick through 2 many channels they will go off and you'll be banned for 10min to and hour. you need to use MgCamd to solve the problem if thats the case.
If its not from russia then your probably paying 2 much PM me
And I dont think this is the place to be talking about `paying to much' and PM you pal..Comment
