help dm 800 se
  • darren08
    • 72
    help dm 800 se
    hi all finally got a dm 800se clone but problems i have all channels for around hr or so then all go if i unplug box and router leave for five min it comes back any help advice greatly appreciated ferrari sim bl82ff
  • beats2006
    • 198
    do freeview channels go off aswell?
    • darren08
      • 72
      dm 800se
      no still getting freeview
      • benny/9
        • 1964
        if your using a server for the chns have you looked in
        the cccam config to see if your cline/s are still there
        i had a image a bit ago and it had a glitch and kept
        booting the line out.
        Please Read Carefully!
        • micflair
          • 275
          Yup, if your still getting freeview stuff then its deffo a net/line/cam problem kid. Is your server reliable?
          • darren08
            • 72
            Server seem good did network test all workin
            • micflair
              • 275
              server `seems' good? You sure on that? also the network test does not test the `server' I am talking about..
              Also, have you checked your router settings? Have a look in there and see if its kicking it off at any point, might not be refreshing the lease for the dreambox IP, thus it wont connect to the net, thus no channels..
              • darren08
                • 72
                hi
                yep server seems ok i have a wimax box providing internet how owuld i go about checking it i know this prob a daft question im still learning
                • micflair
                  • 275
                  Yeah no problem mate! We all started somewhere.
                  Get into your router settings, try 192.168.1.254 in your browser. You need to find your home network bit, and see if there is any problems in that area. Could be that your router is disconnecting your dreambox from the net every so often.
                  When you setup your network on the dreambox, did you use dhcp?
                  • freck
                    • 1076
                    Get Wimax to check out your line...are you having any probs with your connection to pc/laptop whilst the box is on?
                    Do you have enough bandwidth to supply the dreambox and your home internet usage....are family members downloading while the box is broadcasting?
                    Whats your internet speed?,theres a multitude of things to check out if your having this problem.
                    Try answer some of the above and might solve yours.
                    Freck
                    Wimax is not the best in Kerry bud
                    • beats2006
                      • 198
                      Is your service from russia & are you using CCcam with a N Line? if so when you flick through 2 many channels they will go off and you'll be banned for 10min to and hour. you need to use MgCamd to solve the problem if thats the case.
                      If its not from russia PM me
                      • micflair
                        • 275
                        If its not from russia then your probably paying 2 much PM me
                        Ive not heard of that with an N: line and cccam before mate?
                        And I dont think this is the place to be talking about `paying to much' and PM you pal..
                        • beats2006
                          • 198
                          CCcam can use Newcamd Lines hense the N Lines
                          And thanks for your concern!
                          • micflair
                            • 275
                            Yeah Im aware mate that CCCam can use N lines, just didnt know that you can get banned from a server for changing channels..
                            • darren08
                              • 72
                              checked router all seems fine does seem to go when i change channels if i stay on same channel it fine but cant change after that
