DM Home Install
  • marcus1975
    • Jul 2011
    • 248
    #31
    hi
    Where will I find all cfg info to write it down?
    Please can you give an example of info required to write down.
    Sorry my head is scrambled
    [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
    • mark8393
      • 2305
      #32
      It's in var/etc, just copy cccam.cfg
      • southpaw
        • 2233
        #33
        That guide I sent u has info in regarding what to enter. However the subject can't be discussed here. You need to "obtain " a c-line, maybe Google will put you straight
        • Rough Daimond
          • Apr 2011
          • 63
          #34
          he aint got no info in there by the sounds of it..i dont think he even knows where the file is never mind putting any content in their...this is going to be a long drawn out saga.
          Originally posted by JoK
          I would start all over again and flash new image on, I did read that you could not flash another image can you give us more detail as to why or what happens or what is shown in small oled screen on box when you try to flash an image.
          Bear in mind you will loose all cfg info so write it down
          JoK
          • southpaw
            • 2233
            #35
            The problem was he didn't have a config in. Sent him blank one and info how FTP it but he struggled to save it from email attachment .
            Markus. My advice would be to backup when you manage to get it going, then setup USB, then backup. Then sort out epg an backup an so on so on, also read this forum often when you haven't got a problem, that's how we all learn, none of us went to dreambox school, we just read here, play with it an learn, safe in the knowledge we can roll back to last good backup!
            Good luck mate
            • marcus1975
              • Jul 2011
              • 248
              #36
              Thanks for everyones help so far i am now up and running watching lost of channels on 28 E.So next thing sorting out epg with lot of sats 48 E to 30 W if possible? Can some one point me in the right direction
              • marcus1975
                • Jul 2011
                • 248
                #37
                The problem was I didn't have a config file. Southpaw Sent me a blank one and info on how FTP it .Then using foxzila copy and paste it into my directory. Thanks for your help.God DBox can be frustrating but also rewarding.
                Next is to get egp working any advice would be gladly welcome
                Best regards
                Marcus
                • abr
                  • Aug 2010
                  • 108
                  #38
                  will this help?
                  also you will need 1metre motorised dish if you wish to view
                  a few more sats.
                  i use 1.2 cm
                  not a million miles from you
                  i can view from 28 deg to 30 deg
                  • marcus1975
                    • Jul 2011
                    • 248
                    #39
                    Here in the midlands i can pick up 42e to 30w no problems with 90cm dish.
                    Is their a epg for all these sats ?
                    best regards
