Please help with DreamBox 800HD
  • abukeshek
    • Oct 2011
    i was using ibox, and i just bought a new dreambox 80 hd. i have a motor installed, i used to access hotbird, nilesat, hispasat, and astra. the problem with the new dream box, i can't configure the motor and search for channels, i have followed many posts with similar problem, and i tried to follow the indicated steps but it didn't work, when i reach for a certain position, after i click on saving the position and i go to search channels the motor moves alone and it doesn't go back to the position i saved, also even from advanced options i choose several satellites and i save one by one, when i go to motor configuration and i go to chose the satellite i find just one option there.
    the last thing i did, is to connect the old receiver i had, configure the position on hotbird, then i connected the dreambox with a cable when i searched for hotbird channels, i managed to find the channels but i was not able to save to search, when i go to main screen trying to watch channels i find none, and it says that i should check configuration, what i really need is how to configure the motor to find hotbird, nilesat, astra and hispasat. and then how to save the channels.
    as i said before, i read what people sent before writing, i tried the different options and no result.
    thank you in advance.
  • andy91
    • 3583
    Use Usals its easier there is a guide in the red stickies above but choose simple mode and put in positioner as mode like in my picture below.
    Make sure you use the correct longitude and latitude to match your home address,add uptodate bouquets like Catseyes and the motor will autoatically drive to the correct sat you want.
    http://www.digital-kaos.co.uk/forums...47/index3.html post 35
    Andy.
