Dreambox 800HD lost all hd channels
  • andy91
    • 3583
    My mate has lost all hd channels including fta like bbc hd.
    Reflashed and new bouquet and done a scan and nothing.
    Tuner has been set up correctly any ideas boys?
    Andy.
  • southpaw
    • 2233
    Have you tried his box on another dish andy? Could be an lnb issue or failing that his tuner may have a leaking capacitor. Easy to eliminate, try his dish at your gaff an your tuner in his unit, that will confirm if its hardware issues mate
    • andy91
      • 3583
      Hi mate i said to him its probably lnb as we have tried everything else.
      Im in Nottingham and hes in sunny Stoke so cant do that
      Think the only hd channel he gets is Itvhd.Dont think its a transponder problem with vertical or horizontal issues.
      Andy.
      • Freezzby
        • Sep 2009
        • 216
        Hy folks,
        I have a DM800 and I have same issue .
        I don't capt any HD channel .
        I verified the lnb and it's ok .
        Can you show me what capacitor to check ?
        I have a multi-switch EMP Centauri MS-13-8SIA-6 perhaps is the cause ?
        Any idea to help it's welcome .
        Thanks and br,
        Freezzby
        • andy91
          • 3583
          Originally posted by Freezzby
          Hy folks,
          Thanks and br,
          Freezzby
          The only other thing which i think might be a problem is a dodgy power supply.
          Often causes problems to boxes even though it powers the box up.
          Andy.
          • Freezzby
            • Sep 2009
            • 216
            Thanks for the suggestion, but changed the power of the dreambox and thats not the problem.
            I plan to buy a new multi-switch and need 4 satellites and 8 TV's to relies .Can you guys, suggest me something for having my HD channels back ?
            • porter1
              • 559
              ive had similiar when the catseyes settings list wasnt on properly,redone it and eventually got them back
              • stevie brown
                • Oct 2010
                Hi I have the same problem.. Can you explain what the catseyes settings list is and how I go about fixing it like you did?
                Cheers
                Stevie
                • mike d
                  • Sep 2009
                  • 148
                  Cheers
                  Stevie
                  Me too hd channels have gone down to night. the only HD channel working is itv. How do you fix this.
                  • mike d
                    • Sep 2009
                    • 148
                    its fine now just change channel list. Also can anyone tell me which is the best channel list?
                    I use vhannnibal.
