I have recently had a DM800HD play up on me. Was working fine but has recenlty died I will try to explain the issues as clear as possible.
The box will boot to the installed image (Dreamelite) eventually afer a long delay on the dhcp LCD screen. Although it seems to boot successfully, and LCD shows channel info there is no output to TV. i.e via DVI or RCA outputs.
I have tried to reflash the box via Serial but the box fails to communicate with DreamUp.
On first power-up the Ethernet leds light up as normal but about 5seconds after power on they extinguish and never come back on even though connected to router or PC via crossover. They turn off at the point that the LCD screen displays dhcp info. If i hold the power putton on power-up to trigger **stop** and webfront the same occurs. No IP is ever obtained as the ethernet seems to shutdown. As a result i am unable to reflash using the webfront.The ethernet port appears to die 5 seconds after power on.
I have 3 other DM800HD's a 500s and two 500c's and have never enountered this problem. Serial Null Modem cable works fine on all other boxes, my network, cabling and dhcp server are fine. I just cannot successfully connect to this box.
I have opend the box, removed modem, tuner. no change, the box appears to boot successfully according to the LCD screen no error messages however the ethernet LED's still extinguish approx 5 seconds after powere on, and serial will not connect to dreamup.
If i remove the SIM (2.01) then the box will not boot...immediatly giving the boot 'error!' message as expected. However and this is interesting.. the ethernet port LEDs remain lit. Unfrtunatly Serial still will not connect.
The serial bootlog is spitting out jibberish as the box boots.. (as if the serial speed is incorrect) i have tried all speeds including 9600 and 115200 to no avail.
I have tried all the patched dreamup/enforcer techniques including connecting dreamup to another box to connect then switching to broken box to flash but everthing fails to communicate with the box.
Not sure what is going on and i havnt come across anyone else with this kind of problem yet. Can anyone reccomend anything else i can try inorder to salvage this box.
Thanks.
Thanks.
