I have now tried a number of different images and none of them work. The tuner is properly connected in the socket. Previously I had the tuner working on the initial image that came with the dreambox, but after flashing it can not be found.. please help..
i cleared a empty tuner problem using the sunray dreamup
with both the cat5 and the a/b usb cable connected to the service
port on the box,after it connected and uploaded from the box i clicked
the flash button on the loader then loaded the image that way then i re booted the box from the switch on the rear after the image had fully loaded
Please Read Carefully!
once you change to simple and set the frequency you should then be able to scan. Are you on 28.2. If you are still having problems I can send you a copy of my image.
