my dm800se clone does not reckognise the tuner.
  • amegooner
    • Dec 2011
    • 9
    Hi.
    Tuner A: (empty)
    can anyone help me? using pp2.3 btw
  • smirnoff_rules
    • 8603
    can u press arrow left to simple and pick that ?
    • amegooner
      • Dec 2011
      • 9
      No.. Looks like i am missing a driver for the tuner. I've tried two different pp images but none of them has worked.
      • smirnoff_rules
        • 8603
        http://www.digital-kaos.co.uk/forums...-image-226997/ read this m8
        • amegooner
          • Dec 2011
          • 9
          Originally posted by styla
          Sim2-SSL84 Peter-PAN DM 800SE-By sat4fun
          Where can I find the reading drivers app? Will this solve that my dm800se doesn't find the tuner?
          • amegooner
            • Dec 2011
            • 9
            I have now tried a number of different images and none of them work. The tuner is properly connected in the socket. Previously I had the tuner working on the initial image that came with the dreambox, but after flashing it can not be found.. please help..
            • benny/9
              • 1964
              i cleared a empty tuner problem using the sunray dreamup
              with both the cat5 and the a/b usb cable connected to the service
              port on the box,after it connected and uploaded from the box i clicked
              the flash button on the loader then loaded the image that way then i re booted the box from the switch on the rear after the image had fully loaded
              Please Read Carefully!
              • amegooner
                • Dec 2011
                • 9
                the problem is not flashing, that goes alright. But no matter what image I flash, the tuner can not be found.
                Tuner A: (empty)
                • smirnoff_rules
                  • 8603
                  Tuner A: (empty)
                  have u gone into sat tuner settings and turned it to simple or advanced settings
                  • whatsup
                    • Dec 2011
                    • 11
                    Having the same problem but I am at work at the moment and can not try and resolve.
                    Did you get a fix.
                    Cheers Whatsup
                    • whatsup
                      • Dec 2011
                      • 11
                      Thanks smirnoff_rules Worked a treat.
                      • baden06
                        • Dec 2011
                        I've got the same problem what is the reason?
                        • soul65
                          • 45
                          Try this
                          This worked for me i removed the screws that was holding the the box cover on and reseated the tuner
                          • amegooner
                            • Dec 2011
                            • 9
                            I have tried simple, intermediate and expert settings (customize), but that does not change anything.
                            • whatsup
                              • Dec 2011
                              • 11
                              once you change to simple and set the frequency you should then be able to scan. Are you on 28.2. If you are still having problems I can send you a copy of my image.
                              Cheers whatsup
