Just got an email saying that there is now DM800se Sunray SR4 Triple Tuner + Wifi available...now i never even knew a dual tuner was in production never mind a triple tuner
Does anyone know anything about them? can they take 2 feeds or are the other two outputs
Main features are a 400 MHz processor the DM800se Sunray SR4 Triple Tuner and Wifi supports the Linux TV API
Have a look to HighDefinition TV on your Dreambox
10/100MBit compatible Ethernet Interface
HDMI connector
plug & play Tuner
colored OLED display
plug & play slot for an internal 2,5" SATA hard disk
additional an eSATA connector
Technical Features
400 MHz MIPS Processor
Enigma 2, Linux Operating System
colored OLED - Display
MPEG-2 / H.264 Hardware decoding
Tuner: DVB-S, optional: DVB-C, DVB-T
Tuner Module, Plug&Play
2 x Smartcard-Reader (Dreamcrypt CA)
Mini USB for Service and software update
10/100Mbit Ethernet Interface
1 x Scart (RGB, FBAS or S-Video)
HDMI
2 x USB 2.0
analog modem
S/PDIF Interface for digital bit stream out (AC-3)
64 MByte Flash, 256 MByte RAM
2 x SATA
- for internal HDD 2,5?
- one external eSATA
unlimited channel lists for TV/Radio
channel-change time < 1 second
automatic service scan
directly bouquet-lists
EPG (electronic program guide)
multiple LNB-Switching control (supports DiSEqC)
OSD in many languages and skin-support
Videotext Decoder
extern 12V power supply
DreamBox DM 800 HD se technical data
DBS-Tuner mit DVB-S2:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 ? 31 Mbaud/s (8PSK) , 10 ?30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Mini USB service connector:
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Analoge modem:
analoge modem for Internet connection
SATA Interface:
for internal 2,5" HDD and one eSATA
USB
2 x USB 2.0 Host
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
Power consumption:
< 15W at 12V
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0A
Physical specification:
Ambient Temperature +15?C...+35?C
Humidity < 80%
Size (W x D x H): 225 mm x 145 mm x 52 mm
Weight: 940 g without HDD
HDMI connector
plug & play Tuner
Technical Features
HDMI
2 x USB 2.0
analog modem
2 x SATA
Videotext Decoder
Video decoder:
Audio decoder:
Output analog:
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Ausgang Video:
Video parameter:
TV-Scart:
Ethernet:
Analoge modem:
SATA Interface:
USB
2 x USB 2.0 Host
Power consumption:
< 15W at 12V
External PSU
Input:
Output:
12V = / 3,0A
Humidity < 80%
