DM800se Sunray SR4 Triple Tuner + Wifi
  • andy211081
    • 575
    Just got an email saying that there is now DM800se Sunray SR4 Triple Tuner + Wifi available...now i never even knew a dual tuner was in production never mind a triple tuner
    Does anyone know anything about them? can they take 2 feeds or are the other two outputs
    Main features are a 400 MHz processor the DM800se Sunray SR4 Triple Tuner and Wifi supports the Linux TV API
    Have a look to HighDefinition TV on your Dreambox
    10/100MBit compatible Ethernet Interface
    HDMI connector
    plug & play Tuner
    colored OLED display
    plug & play slot for an internal 2,5" SATA hard disk
    additional an eSATA connector
    Technical Features
    400 MHz MIPS Processor
    Enigma 2, Linux Operating System
    colored OLED - Display
    MPEG-2 / H.264 Hardware decoding
    Tuner: DVB-S, optional: DVB-C, DVB-T
    Tuner Module, Plug&Play
    2 x Smartcard-Reader (Dreamcrypt CA)
    Mini USB for Service and software update
    10/100Mbit Ethernet Interface
    1 x Scart (RGB, FBAS or S-Video)
    HDMI
    2 x USB 2.0
    analog modem
    S/PDIF Interface for digital bit stream out (AC-3)
    64 MByte Flash, 256 MByte RAM
    2 x SATA
    - for internal HDD 2,5?
    - one external eSATA
    unlimited channel lists for TV/Radio
    channel-change time < 1 second
    automatic service scan
    directly bouquet-lists
    EPG (electronic program guide)
    multiple LNB-Switching control (supports DiSEqC)
    OSD in many languages and skin-support
    Videotext Decoder
    extern 12V power supply
    DreamBox DM 800 HD se technical data
    DBS-Tuner mit DVB-S2:
    Frequency Range 950 .... 2150 MHz
    Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
    Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
    DVB-S2: 10 ? 31 Mbaud/s (8PSK) , 10 ?30 Mbaud/s (QPSK)
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible, H.246
    Video Formats 4:3 / 16:9
    Letterbox for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
    Audio Mode Dual (main/sub), Stereo
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical, Toslink
    Ausgang Video:
    Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS, RGB, S-Video
    Mini USB service connector:
    Function: Update of Firmware
    Ethernet:
    10/100 MBit compatible interface
    Analoge modem:
    analoge modem for Internet connection
    SATA Interface:
    for internal 2,5" HDD and one eSATA
    USB
    2 x USB 2.0 Host
    LNB power and polarisation per tuner:
    LNB Current 500mA max.; short-circuit-protected
    LNB Voltage vertical < 14V no load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
    Count of active satellite position:
    DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
    Power consumption:
    < 15W at 12V
    External PSU
    Input:
    110-240V AC / 50-60Hz / 0,6A
    Output:
    12V = / 3,0A
    Physical specification:
    Ambient Temperature +15?C...+35?C
    Humidity < 80%
    Size (W x D x H): 225 mm x 145 mm x 52 mm
    Weight: 940 g without HDD
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
  • satsmo
    • 6397
    I have been testing one for about a week now. Nice box and all tuners,(Sat,Cable & Terrestrial), working fine, only a few patched images out at the moment, so have not given it the full run in yet.
    Wifi is also a nice touch, but a dual DVBS2 tuner would be welcomed at some stage. I think that idea has been passed on by a few.
    All in all a nice box at a decent price for what you are getting but the cable side obvious needs an accompanying server here in the UK.
    • lombard
      • Aug 2008
      • 793
      Hi, dont think dvb-c or dvb - t really needed in uk , like said befor dual s2 and wifi would be great make it top box for sure, as built of it and performance is top class
      • lincsat
        • 1228
        DVB-T2 would be a bonus I suppose if you can use 2 tuners at the same time.
        Have you tried using 2 tuners at the same time satsmo or is it like Starview HD Combo, only 1 at a time?
        • satsmo
          • 6397
          It's a combo tuner so yes as you said it is similar to other combos and as such only one tuner works at a time.
          However you could always add a cheap DVB-T stick but that kind of defeats the purpose.
          • wenzuwenzu
            • Jul 2011
            just got one and all is working well DVB-S & DVB-T but when I put my DVB-T channels using DVBGREEK I am loosing all the channels from my list for 28E sat.
            any help please ?
            • bugsy
              • 136
              Hi satsmo,
              How's it going, can you recommend a good supplier for these boxes and any links to images.
              Thanks in advance.
              bugsy.
