faulty hdmi socket dm800se
  • gstar1
    • 85
    i have a faulty hdmi socket on dm800se is it possible to buy a replacement if so best place to buy.
    kevin
  • smirnoff_rules
    • 8603
    have u a maplins local ? DVI to HDMI Adaptor : HDMI : Maplin Electronics = hdmi cable
    • gstar1
      • 85
      the socket on the box itself is knackered
      • benny/9
        • 1964
        i wonder is it the hdmi port on the rear panel
        thats damage and you cant connect a hdmi cable
        from the box to the tv, if it is then the dvi to hdmi convertor
        wont be of any use because there is'nt anywhere to plug it
        in on a se model , but for anyone who wants a dvi to hdmi
        convertor plug they are a fiver at tool station i use one on my 800hd
        Please Read Carefully!
        • gstar1
          • 85
          yes its the socket that connects the box to tv. ?1.75 delivered off ebay for dvi to hdmi converter.
          • benny/9
            • 1964
            last time i had a dreambox repaired it was
            repaired by *** smssat.biz at surrey but i cant remember
            there address. you can ask by email if they can repair your box ,
            • gstar1
              • 85
              dont need a repair just the hdmi socket. just need to find a shop that sells spares. sent them a email to see if they can get one
              • IAmATeaf
                • 591
                Has the socket come of the motherboard? Have read that this was a problem on earlier models of the SE.
                • gstar1
                  • 85
                  it looks to be still be on. if i keep the lead to one side the picture comes on so i am thinkling it just needs a new socket. some one must no a place to buy spares for dream boxes.
                  • gstar1
                    • 85
                    Originally posted by JoK
                    Are you using the HDMI lead that came with box??
                    If so change it first, I have had a couple were the screen is either pink/green and or no pic and you have to wiggle lead around, changing the lead for another 1 has sorted this problem.
                    JoK
                    yea tried 4 different known to work leads. scart works perfect. bummer no hd
                    • gstar1
                      • 85
                      Have we tried box on diff telly, just to be sure it is the box??
                      JoK
                      tried on projector nothing. deffo the socket on the se because if i wiggle the lead around picture will come on tried taping it in place but only lasts for minute or so.
                      • IAmATeaf
                        • 591
                        It does sound like the socket may be loose on the motherboard. Open the box up, plug the cable in and then do whatever wiggling around you do to get the picture whilst watching the connectors on the motherboard.
                        The other thing to check is the actual inside of the socket itself, shine a torch in there and see if the contacts are all lined up.
                        • j1mgg
                          • Feb 2011
                          • 61
                          This happened on my 800se and it finally came off the board"
                          , took it to a tv audio repair shop and they fixed it but it never lasted long. Scart works though.
                          Best bet is a tv repair shop.
                          • IAmATeaf
                            • 591
                            What, did it come off again? Any person competent with a soldering iron should be able to resolder it back on unless the connector or the actual tracks themselves have become damaged as a result of it originally coming off.
                            • j1mgg
                              • Feb 2011
                              • 61
                              No, It was still soldered well but just never got the signal.
                              it was the tracks that were broken at the start.
