How can I use my Sky subscription in my DM 800 HD?
I've been able to install additional CCcams but I can't activate them from Camd in the blue panel. 2.1.4 is still activated
help much appreciated
You press right and left in the blue panel cam selector.
Move to CCcam 2.1.4 (using up/down), then press right/left to navigate to `Common Interface` or `CCcam 2.2.1`.
If you still cant see it, try rebooting (although this is not needed).
- Thanks to those who deserve them, and none to those who don't...
- DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
- weedman
Hi guys, sorry to hijack someone elses thread but couldn't help myself. been reading through this thread and find it very interesting and can't help but ask, can I use the same procedure to activate my sky card on spiderbox 9000hd or the instructions here are only for dreambox???
you can use the boxkey in the spiderbox to get the chanels working if you have a sub with sly. spiderbox has cccam and newcamd....................so no problems there.
got CCcam 2.2.1 working and have the boxkey in the .cfg file but still doesn't work. How can I tell if the boxkey is correct and the sky card has the correct rights?
I'm a bit confused about how to generate a boxkey as information seems to differ
some threads say to use the 17 digit code on the bottom of the box - the serial number I have is only 16 digits - and use a keygenerator
Some threads say use the 10 digit code from the menu s/n and just convert to 8 digit hex
Other threads say take the first 2 digits of the 10 digit menu to make 8, convert this to hex - I think it says this gives a 7 digit hex key but in my case I only get 6 digits - and then add a zero to the front
Anyone explain the reasons or give clarification or point me at a reliable thread?
