Do as "Hibbydave " says and make sure u FTP the same version of TSpanel to tmp as you write in telnet - 4.8 being the latest , works every time for me.
the tspanel loading and usage info
you load this addon after the image of your choice is flashed
open the dcc and click [TOOLS] then [packages]
in the green section on the left of the panel
a list of the packages on your dreambox will upload
under the list are two bar strips [update package list]
and [upload package] click upload package bar a window will
open find and click on th tspanel file then click open on the
window the file will now load on your package list and will give
the loading info in the protocol pane under the package list.
once loaded,close the dcc and re start your dreambox when it
re boots you will find the tspanel in your menu list ready to use
and get to the extras for your image, like cams/config /skins etc:
the other way to load it is by opening the dcc and
d/l clicking the tmp folder in the left pane to open the folder
then you highlight thr tspanel in the right pane and use the arrows
to send the file into the tmp folder then you close the dcc and with
your remote you press blue for this image and from the list find
manual install>ok and you will see the addon in the panel click ok
and load the addon and once loaded re start the image and you will
find it as above ready to use.
with some images there is no manual install feature so load as above,
best regards
marcus
[I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
