Merlin-3.dm800-120216_wahid_sim201#ssl84b
  • NICETOBNICE
    • Nov 2011
    • 551
    just flashed with this image but cannot see how to install my ts panel i have placed it in the tmp folder but dont no how to install it
    help
  • HibbyDave
    • 28
    copy the ipk file to /tmp
    copy the following command and paste in dcc-telnet then hit enter
    opkg install -force-overwrite /tmp/enigma2-plugin-extensions-tspanel_4.8_mipsel.ipk
    "I did not need any persuasion to play for such a great club, the Hibs result is still one of the first I look for"
    Sir Matt Busby
    • NICETOBNICE
      • Nov 2011
      • 551
      tried to install in tmp in filezilla but cant find it in the image
      • shankill2012
        • Feb 2010
        • 285
        Do as "Hibbydave " says and make sure u FTP the same version of TSpanel to tmp as you write in telnet - 4.8 being the latest , works every time for me.
        • marcus1975
          • Jul 2011
          • 248
          Hi NICETOBNICE
          Try this my friend benny/9 showed me this way
          the tspanel loading and usage info
          you load this addon after the image of your choice is flashed
          open the dcc and click [TOOLS] then [packages]
          in the green section on the left of the panel
          a list of the packages on your dreambox will upload
          under the list are two bar strips [update package list]
          and [upload package] click upload package bar a window will
          open find and click on th tspanel file then click open on the
          window the file will now load on your package list and will give
          the loading info in the protocol pane under the package list.
          once loaded,close the dcc and re start your dreambox when it
          re boots you will find the tspanel in your menu list ready to use
          and get to the extras for your image, like cams/config /skins etc:
          the other way to load it is by opening the dcc and
          d/l clicking the tmp folder in the left pane to open the folder
          then you highlight thr tspanel in the right pane and use the arrows
          to send the file into the tmp folder then you close the dcc and with
          your remote you press blue for this image and from the list find
          manual install>ok and you will see the addon in the panel click ok
          and load the addon and once loaded re start the image and you will
          find it as above ready to use.
          with some images there is no manual install feature so load as above,
          best regards
          marcus
          [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
