I have two DM800 HD, one is working fine but the second has a problem when I connect HDD (internally or as E-SATA).
When I flash the dreambox (with or without HDD) it completes successfully. Then after power off, I have connected HDD, power ON and it starts OK. Dreambox finds the HDD as correct model and size (Seagate 500Gb). I run HDD initialisation and it finishes with no problem. After reboot it hangs at the boot stage. If I disconnect HDD then Dreambox is working fine.
The same HDD has been tested in the second Dreambox OK (boxes are identical-purchased the same time), both are imaged with the same image (currently Dream-exp-dm800hd-patched-by-voyger - have tried several images with the same results).
Are there any settings that I need to check?
Thanks in advance
P.S.
Have tested the HDD under Windows 7 - couldn't find any problem with it.
Thanks in advance
P.S.
