Hi all , im quite good at reflashing dm800 and dm800se , and also from na ca error etc, but i have this one DM800hd Se latest with mini flash,
ok with noting connected just power when you switch on it will give IP address on front oled screen , even though no network cable connected, then comes up Dream loading, but noting on screen,
reflashing holding the front power button, just gives same IP address even if no network cable connected,
so tried the mini flash at back, that says na ca or second flash failed then give same IP address as it always does, wont connect,
then tried Sunray Flasher, which seems to work and lets me flash via browser everthing seems fine goes to 100% and done, but once reboot, still same just gives exact same IP address as it always does, strange that sunray flasher worked and let me flash image but doesnt seem to do anything,
I have taken out tuner, cleaned sim card, does this look faulty ?
