Wireless LAN on DM800
  • radioham
    • 151
    #16
    Originally posted by radioham
    Just bought a TP Link wireless dongle from Microdirect.co.uk for ?14.69,have got my DM800HD working on 28.5e,using the original Gemini image as supplied but still can't find any reference to installing a WLAN.On my receiver the dongle is not activated,the active LED is not illuminated and the dongle does'nt get warm,so assume there is no volts being supplied to it.Anyone got any decent ( none rude)suggestions???Cheers Chas.
    Here's an update,I now have a DLink Wireless USB dongle using the RT73 chipset,and the setting up is ok,it recognises my network but won't connect to it,baffled!!!!!!!!!!!!!!!Cheers Chas.
    • 3axes
      • Feb 2010
      • 5
      #17
      I have dm800hd with gp4.5 and boot loader 75
      There is also no option of wlan
      could any body help about this issue
      • Appen
        • 51
        #18
        same problem here, I have started up the Wlan kernels but no go. The usb wlan is found, but no where to activate wireles lan ;-(
        Any good ideas?
        Reghards
        Appen
        • radioham
          • 151
          #19
          So here's another update,the DLink dongle seems to work OK and recognises my network,but it won't talk to my router.And I think I know why!!Installing all your normal settings in the setup is OK,BUT these settings apply to the box,NOT the dongle.Remember that the dongle is a device external to the box and not part of its system,so any settings applied in the box won't apply to the dongle.If anyone knows how to gain access to the box system setup for the dongle,I and I guess a lot more people would like to know!!For the present I'm using a pair of Power Line Adaptors.Hope this makes sense and helps.Cheers Chas.
          • Oadbylad
            • 46
            #20
            Devilfish (or some one) can you please clarify what image this guide is based on as it would appear on newer images the Wlan feature is not available and i would like to try it even if it means rolling back to an early image
            Thank you for your good work
            • fir3fox
              • Oct 2011
              #21
              does this Wlan working on a Newigma:2011-03-18-Yang with image : Newnigma2.V3.2.2 0110-32-4 ???
              Great ful for hints
              • lombard
                • Aug 2008
                • 793
                #22
                you can download wireless drivers from tspanel
                • fir3fox
                  • Oct 2011
                  #23
                  Thank you for this tip, I dl wlan v1.0 from ferrari plugin and install it at the box, how do I know when/how the wlan dongle is installed and working?!
                  • fir3fox
                    • Oct 2011
                    #24
                    Thank you for this tip, I dl wlan v1.0 fix, sorry for typing it wrong, but I dont think thats a driver for lan, just a fix ?!?
                    • lombard
                      • Aug 2008
                      • 793
                      #25
                      on tspanel you goto sim2.01, extras , usb wireless drivers, dont know if you got that on ferrari addon
                      • ash213
                        • Apr 2009
                        • 64
                        #26
                        i dont have wlan option....how do i get it chaps?
                        • colly127
                          • Nov 2010
                          • 25
                          #27
                          Plug ur wirless usb in Reboot the box go into network settings and u will see it
                          • afcgunners
                            • Apr 2012
                            • 5
                            #28
                            I am having problem connecting my dream box, i have got Static Ip address. I have gone into the DB and followed the steps for connecting to the network, i have put the details in and turned of DHCP. It connects to the router network, but when i do a network test it fails to register the Ip address. WLAN connects but the other box are all crosses......
                            When I took the DM to my cousins it worked all fine, he has standard broadband connection. I think this is the issue, if so can it be resolved or do i need to go to the standard broadband provider instead of Static????
                            Please help its doing my head in..........
                            • lombard
                              • Aug 2008
                              • 793
                              #29
                              what provider you with ? wired you cant just simply connect to router as would normally,, what about other stuff on your wireless you got laptop , phone connected etc ??
                              cant you just go into router firmware and turn off static IP ?
                              • ignatis
                                • May 2011
                                i have this problem on my wlan option.my wifi password contains < > how put this symbols?On 0 key there arent any keys like these < >.are possible to add them???
