Hi, I hope someone can help. I'm a bit of a newbie when it comes to the dreambox. I am running a DVB800 HD PVR with enigma 2. I was trying to up date the chanel lists / bouquets using Dreambox Control Centre E2 and deleted all files in FTP\etc\enigma2 by mistake. I them tried to copy file in from the folder that I had downloaded (SGTFlipFlop ENiGMA2 16.04.12) but for some reason contents wouldnt transfer. I then went into settings and tried to restore a backup that I had made before I started the above. Now my box freezes on bootup. Can any one help please
DM800 HD PVR Clone failure to boot
Thanks for your answers,.
Lincsat, I have tried looking for info on doing a standard firmware load and where to get firmware, could you point me in the right direction please.Comment
here is the best way
Quick tut to repair NO CA on all DM800HD
Please use patched version Dreamup
1. connect via serial using NULL Modem cable and Ethernet to router and pc.. ( if you don't have a Null modem cable you can purchase here null modem cable found EDITED.. ANYWHERE
2. load patched version of dreamup, select your com port and then click connect and power on dm800
3. when initialised it will display http serial mode on lcd and show dhcp ip once ip is displayed dreamup as served its purpose and now its in flashmode
4. log into webshell on pc using the 192.168.x.xxx address on LCD disply and flash as normal
then after all done you will need dremboxedit to upload you sky channel listComment
Press and hold the front power button whilst powering up the box, keep holding the front button until STOP appears. Then you get an IP address to enter into the browser on your PC.
Have a look in the downloads section for an image but do make sure it's for the correct SIM for your box.Comment
