Box crashes after EPG download.
  • gazaman
    • Jun 2012
    • 27
    Hi All.
    I'm using nabilosat blackhole v0.12 image. I know its old but for my DM800HD clone it seems the most stable,smooth and reliable except for one thing....
    Every now and again (mostly weekends though, which maybe just coincidence) the box crashes after downloading the EPG. I have tried both Satmate uk and Rytek uk and it happens with both. Its not all the time but quite annoying all the same.
    I've tried installing ts panel to enable me to use cross epg but ts panel wont install.
    Does anybody else have any suggestions?
    Thanks in advance
    Gaz
  • gavin80
    • 38
    Where are you saving the epg. Make sure its on a usb stick or externall hdd and not the internal flash as it will use up the flash memory causing the box to crash.
    • gazaman
      • Jun 2012
      • 27
      Cheers mate.
      Ive actually tried using both USB and the HDD but with the same results.
      Was kind of hoping I could use cross epg to see if this is any better but not sure if I can get it on this image.
      • gavin80
        • 38
        Try this image
        DreamboxUK_v2.1.1_SIM2_84A_DM800.nfi - 4shared.com - online file sharing and storage - download
        Very stable for clones and has cross epg built in.
        • gazaman
          • Jun 2012
          • 27
          Try this image
          Unfortunately,I'm stuck on an old bootloader (70) and my box doesnt like any of the newer images (believe me,I've had a few headaches trying).
          It seems the only way round it is to try and install cross epg manually.
          Thanks for the suggestions though mate, appreciated.
          Gaz
          • gavin80
            • 38
            Downloads - crossepg - An EPG for enigma2 based dvb receivers - Google Project Hosting
            • gazaman
              • Jun 2012
              • 27
              Cheers pal,
              How the hell are you supposed to know which one to get?
              Theres not really any info on the files.
              Gaz
              • 00360362878
                • Mar 2010
                • 488
                Originally posted by gazaman
                Cheers pal,
                Gaz
                Hi mate
                You can give this one a go, I was told by perisian prince that this version was compiled for perisian empire, but will work on any mipsel STB.
                I haven't tried it because I now use EPGimport which works perfect for me using PLI.
                • gazaman
                  • Jun 2012
                  • 27
                  Originally posted by 00360362878
                  Hi mate
                  Thanks mate, I'm not sure what "any mipsel STB" means but I'll give it a whirl
                  I've left it untill now cos I'm a bit worried about bricking my box (again).
                  Rytec seems the best up to now but crashes on download every single sunday. Thing is,I only get the option to auto download every day and no option to miss sunday (I have no idea why its just sunday by the way).
                  Also rytec sometimes doesnt provide show info on the right of the screen when browsing bouquets.
                  I just need a good,stable, hassle free EPG downlader so I'll give the one above a wirl and report back.
                  Thanks again
                  Gaz
                  • gazaman
                    • Jun 2012
                    • 27
                    Hi mate
                    No such luck. It just wouldnt install at all so obviously not compatable.
                    Thanks anyway.
                    Any idea where I can get a compatble file?
                    Cheers
                    Gaz
                    • 00360362878
                      • Mar 2010
                      • 488
                      have you tried installing from Tspanel?
                      • gazaman
                        • Jun 2012
                        • 27
                        I tried FTP ing a version of ts panel to my box but again,I think that was also incompatable as it wouldnt install.
                        I have gone to plug in downloads but TS panel aint there so manual install needed.Ive tried searching for a version of ts panel but being the noob that I am,I dont know which others to try without doing damage.
                        Can I actually brick my box trying to install incompatable plugins or would they simply just not work?
                        Gaz
                        • 00360362878
                          • Mar 2010
                          • 488
                          I don't think they are incompatible, how are you trying to install them. You can install using ftp into tmp folder or copy them to you usb stick, then install through software manager.
                          When you try to install do you get any on screen message?
                          • gazaman
                            • Jun 2012
                            • 27
                            Yeah,I cant remember what the messages said though.
                            After having a ggood look round,I came across this...
                            Maybe this is the reasn I cant install????....
                            Thanks for your help
                            Gaz
                            • 00360362878
                              • Mar 2010
                              • 488
                              Flash a more upto date image seems your next move.
