This is why I've not bought one yet.Same price as M tuner delivered from mixishop.
Tempted to get the M tuner its not like there are bad reviews about them.
Andy
I've bit the bullet and ordered one with the new G tuner.
Yaoxin say it's meant to be better than the M tuner and gives a stronger signal so will report back.
Will probably stick to the Dream Elite image.
Quick update i got nemisis to work and dream elite 3.0 but as soon as i loaded bouquets all was fine for a mminute thn the light on both the box and the psu started to flash and guess what empty tuner again. Could smell something like tcp so Im guessing something has blown.
Think Im going to send it back not happy.
i recieved dm800hd with rev g tuner, doing a quick check i notice the motherboard says rev g on it as well, i usually use dbuk 2.1.2 image and it works fine, also signal on bbc hd is 100% like rev m tuner got, aint had time to test properly yet, will get back also if it gets hot like the rev m tuner
i know i keep saying this but why do people keep buying from yoaxcin/mixeshop? there are countless complaints all over the web about their qc and returns/customer service... when will people learn these thieves cant be trusted!!!!!!!!!!!!!!!!!! regards mdt
its BCM4505 , been running it for a day now , no issues at all so far and seems it does run cooler then rev m tuner, the signal seems to be higher as well, but would need to check that again on different channel when using rev m tuner and same weather conditions to be sure
