hello i was wondering if anyone can help.. i bought a Dreambox 8oo pvr.. i admit i dont know to much about recievers but as i had a krypview before i thought how different could it be to set up... so anyway i was going through menu screen , i went into software managment and it said updates available so i accepted it loaded finished told me to switch off the box then it crashed. now the box is on , tv screen is black and stanby wont switch on off.. is it just a case of having to reinstall new software .. any help much apreciated
dm 800 hd , box crashed
if you can get a ip address by switching it off at the back and back on while holding the standby button then do so if not you will need to recover it with a null-modem patch lead and you can find a tut in the dreambox section(no ca error fix). online software updates are for original boxs ad should not be used when running patched images on clones,regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
Hi I'm a newbie and I have a similar problem with my DM800se ie. have the ca error and would like to say thanks for the info I now know where to start to fix it.if you can get a ip address by switching it off at the back and back on while holding the standby button then do so if not you will need to recover it with a null-modem patch lead and you can find a tut in the dreambox section(no ca error fix). online software updates are for original boxs ad should not be used when running patched images on clones,regards mdtComment
