all channels failed after hd tuner failed
  • nalle077
    • 13
    Hello. I have a strange problem. directy when I change to a HD channel the snr gets 0 and no matter what I do all channel ( SD and HD) gets tuner failed. I have tuner rev J so I think the old cap fix will do it but can anybody confirm this. By the why I have DM800HD PVR old one from 2009 with new sim 210 and image openpli 2.1. I think the box cools quite good with the fan. Can you drive the box without fan or does it break? best regards
  • southpaw
    • 2233
    Re: all channels failed after hd tuner failed
    Yes the cap replacement will give you hd signal on a rev j tuner, and the box can run without fan but as with all electronics the cooler the better
    • nalle077
      • 13
      Ok but I was thinking about the thing that more heat would start hd channels again. because I had to wait a while before the HD channels strated to work earlier.
      • southpaw
        • 2233
        best to tackle the issue at hand mate, don't run the box hot just to get around the tuner issue as it will possibly shorten the life-span of the unit, do the cap fix or better still upgrade to a rev -m
