hi BD,i used this instead of dreamup to fix my box of software problem ...greenscreen...using null cable? but it said it fixed it, so then i plugged back in and the same image was there yet still got greenscreen after couple of minutes ...i then web flashed another image and got green straight away...my box is a dm800hd pvr on sim201 , 84b any ideas? cheers micky
flashed wrong image
Did you choose the correct bootloader for your box. I've used this a few times and never had any problems mate. When it repairs it flash it via browser.
If your box is accepting the image and is correct image, chances are you got a hardware issue thats causing the green screen,hi BD,i used this instead of dreamup to fix my box of software problem ...greenscreen...using null cable? but it said it fixed it, so then i plugged back in and the same image was there yet still got greenscreen after couple of minutes ...i then web flashed another image and got green straight away...my box is a dm800hd pvr on sim201 , 84b any ideas? cheers micky
Take box apart and check connections ie tuner etcsigpic
"Make it idiot proof and someone will make a better idiot."Comment
Ok pal I will check tommoz when home, thought I sorted it earlier look stable until scanning then green screen again...Comment
Yeh bd I flashed ssl84b first as well and then image,seems to go off on scan, the Ethernet loses connection then green screen shite!Comment
Try booting it up without ethernet connected. Dont scan see how long it lasts.
If lasts a while then scan or try sending catseyes over to the box and see if you can get BBC1 or any other FTA channels
And my REV M tuner was ?30 from ebay.sigpic
Thanks for this forum. I also have the same problem, but i can connect dreamup with my dreambox. But when i flash with some images, it will not boot up but NO CA CARD FOUND. Please which one is the best image for DM800HD PVR sim 2.01 and how do I know the ssl?Comment
are you using a patched dreamup loader panel?
if not you can download one from this link to clear your box
Digital Kaos - Downloads - dreamup patched by forhike and natasPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
how much are tuners?
