flashed wrong image
  • mickydibble
    • 2166
    #16
    Originally posted by Bulld0g
    hi BD,i used this instead of dreamup to fix my box of software problem ...greenscreen...using null cable? but it said it fixed it, so then i plugged back in and the same image was there yet still got greenscreen after couple of minutes ...i then web flashed another image and got green straight away...my box is a dm800hd pvr on sim201 , 84b any ideas? cheers micky
      Did you choose the correct bootloader for your box. I've used this a few times and never had any problems mate. When it repairs it flash it via browser.
      • southpaw
        • 2233
        #18
        yeh, think I used bulldogs method too, was a while ago but think it stuck on "calculating checksum" but was still able to flash via usual browser method
        • cunny
          • 4915
          #19
          If your box is accepting the image and is correct image, chances are you got a hardware issue thats causing the green screen,
          Take box apart and check connections ie tuner etc
          • mickydibble
            • 2166
            #20
            Ok pal I will check tommoz when home, thought I sorted it earlier look stable until scanning then green screen again...
            • cunny
              • 4915
              #21
              Re: flashed wrong image
              Could be a tuner issue. Ive just had to change mine
              Sent from my GT-I9300 using Tapatalk 2
              • mickydibble
                • 2166
                #22
                Yeh bd I flashed ssl84b first as well and then image,seems to go off on scan, the Ethernet loses connection then green screen shite!
                • mickydibble
                  • 2166
                  #23
                  Was it doing the same as mine,and is it ok now,and how much are tuners?
                  • cunny
                    • 4915
                    #24
                    Try booting it up without ethernet connected. Dont scan see how long it lasts.
                    If lasts a while then scan or try sending catseyes over to the box and see if you can get BBC1 or any other FTA channels
                    And my REV M tuner was ?30 from ebay.
                    • coolsegun
                      • Mar 2013
                      #25
                      Thanks for this forum. I also have the same problem, but i can connect dreamup with my dreambox. But when i flash with some images, it will not boot up but NO CA CARD FOUND. Please which one is the best image for DM800HD PVR sim 2.01 and how do I know the ssl?
                      • benny/9
                        • 1964
                        #26
                        are you using a patched dreamup loader panel?
                        if not you can download one from this link to clear your box
                        Digital Kaos - Downloads - dreamup patched by forhike and natas
                        Please Read Carefully!
