weak signal on hispasat on some transponders,can u help
  • ricardo1980
    • Aug 2012
    • 9
    im having some signal problems,on a transponder its :hispasat 1c -12092.00-h-3/4,all other transponders are ok this seems to be a bit weak,somtines I get a pixely picture (not watchable)I don't know if this is a weak transponder,anyone else have trouble with this one,i have a dreambox 800hd with a 60 cm satellite dish,with about a 25ft cable run on a disq switch.in the southwest of elgland.. thanks and regards ricardo
    Its a DVB-S2 8PSK Transponder which can cause some problems for certain receivers, Can you try another receiver at all as the 60cm dish should have no problems picking this up everything points towards the DM800 Tuner with it being a DVB-S2 TP.
    • ricardo1980
      • Aug 2012
      • 9
      thanks for reply no I don't have another reciver,heres my info::
      Devicename: dm800
      Enigma Version: 2010-07-21-experimental
      Image Version: Experimental 2010-07-21
      Frontprozessor Version: VNone
      Webinterface Version: 1.6.2
      Tuner A: Alps BSBE2 (DVB-S2)
