Dreambox hd800 clone green screen on boot up
  • fordie73
    • Jan 2014
    • 19
    Hi guys
    I am new to the forum and desperate for some help on my dreambox.
    i recently downloaded some software off tspanel not sure what it was though,all I do know is after the dreambox rebooted it gets to around 3 quarters on boot up and it then gets a green screen with all information on it and the reboots it then does the same process over and over again.
    I tried to re flash the unit but my computer would not link up with the unit I tried using loads of different internet browsers and also different software but still no joy.
    I even asked a friend who really good with dreamboxes and reflashed the unit before but he also had no joy.
    It has to be something to do with the add on I downloaded as it was working fine before.
    I have enclosed a picture to show the error.
    Any ideas I'm gutted at the moment
    THanks
  • andy91
    • 3583
    Won't it let you try and flash holding the power button in on boot up, web browser method?
    Andy.
    • fordie73
      • Jan 2014
      • 19
      No tried that but never worked my computer did link with the IP address but nothing happened tried all different browsers and image software but never worked.My friend also tried with the image software he used on the unit last time but it never worked for him?
      • andy91
        • 3583
        Strange you get an ip address up and web browser don't work. Looks like its dreamup then with null modem cable.
        Andy.
        • fordie73
          • Jan 2014
          • 19
          Yeh I think I will give it a try and take it from there is there different types of null cable also were is best to get one?
          cheers for the help andy
          • southpaw
            • 2233
            you need to check what connection your pc has mate, as most modern pc`s don't have rs232 , therefore you may need a usb to rs232, google rs232 to give you an idea of what to look for
            • andy91
              • 3583
              Always better to use desktop pc if you can with Windows XP.
              Andy.
              • fordie73
                • Jan 2014
                • 19
                Thanks guys for your help going to try and get the lead today and have a go tonight
                • fordie73
                  • Jan 2014
                  • 19
                  Hello I got the lead sorted but my computer wouldn't connect to it ,However I managed to get the dreambox to connect via dcc and that seems to be the only way I can talk to the unit is there any way I can reflash the dreambox via dcc I have noticed there is an option in the tools section of dcc.Does anyone know how I can do this it seems to be last chance saloon?
                  As I am not very good at this can the directions be as simple as possible please
                  Thanks again for your help!!
                  • fordie73
                    • Jan 2014
                    • 19
                    Sorry forgot to say I tried the lead with dream up but it wouldn't connect!
                    • southpaw
                      • 2233
                      you need a certain version of dreamup mate, as some wont connect, also check your power supply as these often fail and wont output the correct 12v
                      • southpaw
                        • 2233
                        DreamUP Patched dm800 clone - Downloads - Digital Kaos use the null connection but also keep your network cable attached
                        • fordie73
                          • Jan 2014
                          • 19
                          Ok cheers I'll give it a go
                          • fordie73
                            • Jan 2014
                            • 19
                            Hi guys still no joy I purchased the rs232 lead from maplins installed the drivers all seemed ok I then started up dream up version v1.3.3.11 but it never connected I also tried a different version of dream up and again no connection I also tried various usb inputs but again no joy ,Strange though as dcc does connect one thing that is strange though on the dcc network connection all goes green but in the protocol bit at the bottom there are no details,
                            Any ideas
                            • southpaw
                              • 2233
                              make sure your using correct com port, open "device manager" and check what changes when you plug in the usb/null cable as that will flag up which port it is assigning
