Dm800se wifi
  • roblfcx5
    • Nov 2012
    • 239
    Dm800se wifi
    Hi guys I no the dreambox being hardwired to internet is best or the option to use home plugs, but does anyone use the WiFi on the 800se ? And if so is it stable enough or should I purchase the homeplugs
    Sent from my GT-I9505 using Tapatalk
  • smirnoff_rules
    • 8603
    get a 300Mbps Wireless-N 802.11 AP WPS Wifi Repeater Range Extender Router Booster UK | eBay instead m8 u can hardwire to this to and get better wifi around the home , better than homeplugs
    • roblfcx5
      • Nov 2012
      • 239
      Thanks smirnoff
      So this boosts ur WiFi up, how would you hardwire to it
      Its only the one piece isn't it ?
      • southpaw
        • 2233
        i believe it speaks to your network over wifi mate, then has an input port (ethernet) for connecting a device directly wired , obviously its connecting to your router over wifi tho.
        dont own one btw, just looked at specs and assume the above
        • southpaw
          • 2233
          sorry, double post, dk site playing up tonight
          • smirnoff_rules
            • 8603
            Originally posted by roblfcx5
            Thanks smirnoff
            only need one unit , sync with your router then put anywhere in your home , best place in a poor wifi area , if you want theres a port to hotwire to dreambox aswell and still boosts wifi around your home
            • roblfcx5
              • Nov 2012
              • 239
              Ordered the same one on eBay for ?9 wil see how it does, i could also do with a boost of WiFi for the upstairs anyway.
              • southpaw
                • 2233
                If you have an old router you may be able to achieve the same by running it in repeater mode, with the added benefit of probably 4 Ethernet ports to hard wire into, most newer routers are capable of repeater mode
