CA NOT FOUND
  • hunsbedt
    • 4
    CA NOT FOUND
    Hello. I bought a 800HD clone.
    I have installed a image. And now i get the message CA NOT FOUND... Help me. What can i do??
  • pob639
    • Feb 2008
    • 224
    help us out m8
    what image you install ?
    how did you flash your box ?
    what sats you after ?
    what subs you got ?
    what cams you've installed ?
    then i'll try and help i,ve just brought an original 800hd but still in box saving it for wknd
    • on_the_jazz
      • 557
      You've used an image with a newer bootloader than your box supports.
      Try flashing an image with a lower BL version. Maybe Nabilo with the BL69 loader.
      You'll have to do this the slow way with DreamUp. It shouldn't take you more than an hour to flash.
      btw try introducing yourself in the relevant thread.
      • cauliflower69
        • 261
        Same thing happened to me with bootloader 72 box using a 72 image. Worked fine for three weeks then this.
        Make sure taht you use the latest version of DreamUp as the earlier versions do not work
        • hunsbedt
          • 4
          Originally posted by pob639
          help us out m8
          what image you install ? Enigma 2
          how did you flash your box ? I wired it to my router and then logged inn on its ip
          what sats you after ? ?
          what subs you got ? ?
          what cams you've installed ? I installed it and it didn't start up after.
          See above...
          • hunsbedt
            • 4
            Ok. I am an Norwegian and im new on this ;-)
            • hunsbedt
              • 4
              I tried the slow way. But i did not manage to connect with the tuner... Please help me. Dream up says when i connect : Turn the tuner on. But the tuner is on. Iss it the cable?
              • DM800
                • Aug 2009
                • 21
                flash Gemini 4.4 from here
                your box will be working after you flash it
                • Oily
                  • Apr 2009
                  • 123
                  Make sure everything is unplugged,even the power.Connect up your null cable,run Dreamup,press connect then go plug the power into the box.It should connect,that's the way i did mine yesterday.
                  • dedalos
                    • Apr 2009
                    • 11
                    little help and here
                    I have a clone DB 800HD with BL 75 sim 2.0.1 and enigma 4.4
                    From yesterday I got the massage in the frond panel : erro1 :No CA found :
                    After I read all the topics about it , I was able to flash ( with dream up ) my box with bL 72 ( flashing with BL 75 even it was shown ?flashed successful? after re plugging the machine I had the same ?erro1? . ) now the machine boots only half way ( the bar in frond panel ) and freezes . Please Help . what I should do ?
                    • ROGER_L
                      • Aug 2009
                      • 4
                      TRY IMAGE= NEW GEMINI 4.60 FOR YOUR CLONE.
                      download=DreamboxClones.co.cc should sort out your probnlem. HAPPY NEW YEAR TO ALL MEMBERS ON THIS GREAT SITE.
                      • dedalos
                        • Apr 2009
                        • 11
                        thanks a lot i download from the above and everything is back to normal
                        thanks again
                        • Lanzabauf
                          • 5
                          i got it and tryed it...but my dreamup tells me "the file is to big".....?????
                          why?.....
                          • kaitum
                            • 19
                            I had the same error--> No CA found by 2nd stage loader, please contact support at dream-multimedia!
                            Tested enfocer and dm800_repair. Got the messeage " file is to big " when i got dreamup to work whith enforcer.
                            No CA found by 2nd stage loader means Certification Authority not found --> wrong sim answer.
                            It works whit a new sim.
                            • rojus
                              I have htis problem too. I tried to repair with dm800_repair, but not succesfuly.
                              How resolve this problem? Any idea.
