You've used an image with a newer bootloader than your box supports.
Try flashing an image with a lower BL version. Maybe Nabilo with the BL69 loader.
You'll have to do this the slow way with DreamUp. It shouldn't take you more than an hour to flash.
btw try introducing yourself in the relevant thread.
what image you install ? Enigma 2
how did you flash your box ? I wired it to my router and then logged inn on its ip
what sats you after ? ?
what subs you got ? ?
what cams you've installed ? I installed it and it didn't start up after.
then i'll try and help i,ve just brought an original 800hd but still in box saving it for wknd
I tried the slow way. But i did not manage to connect with the tuner... Please help me. Dream up says when i connect : Turn the tuner on. But the tuner is on. Iss it the cable?
Make sure everything is unplugged,even the power.Connect up your null cable,run Dreamup,press connect then go plug the power into the box.It should connect,that's the way i did mine yesterday.
I have a clone DB 800HD with BL 75 sim 2.0.1 and enigma 4.4 From yesterday I got the massage in the frond panel : erro1 :No CA found : After I read all the topics about it , I was able to flash ( with dream up ) my box with bL 72 ( flashing with BL 75 even it was shown ?flashed successful? after re plugging the machine I had the same ?erro1? . ) now the machine boots only half way ( the bar in frond panel ) and freezes . Please Help . what I should do ?
I had the same error--> No CA found by 2nd stage loader, please contact support at dream-multimedia!
Tested enfocer and dm800_repair. Got the messeage " file is to big " when i got dreamup to work whith enforcer.
No CA found by 2nd stage loader means Certification Authority not found --> wrong sim answer.
It works whit a new sim.
I have htis problem too. I tried to repair with dm800_repair, but not succesfuly.
