CA no card found / File too big
  • sapcons
    • Sep 2009
    • 15
    Hello. After some problems with my DM800 clone I decided to upload a new image. Everything was ok until I rebooted the box.
    The box came back with a 'CA no card found' error. No IP. Nothing.
    I downloaded the "2nd stage pack", but all these messages do never appear in DreamUp. When I select the file to flash the box DreamUp immediately stops with a 'File too big' error.
    Did I select the wrong BL file?
    What else can I do?
    Thanks for your help
  • kevin64
    • 170
    just flash you bl back on and image will work 2.0 sim here http://www.digital-kaos.co.uk/forums...otloader-1002/
    2.1 sim here Digital Kaos - Downloads - clone 75 boot loader only for 2.1 sims just flash it the same way you would flash a image take about 10mins to do ok
    • sapcons
      • Sep 2009
      • 15
      Thanks Kevin.
      To make sure that we have the same understanding: DreamUp doesn't show any error when I connect the PC with the box.
      This 'No CA found' error is only displayed on the box. DreamUp doesn't show anything re this.
      It might be possible that I have flashed the box with the wrong nfi (for originals)
      • sapcons
        • Sep 2009
        • 15
        No ideas? I really need your help
        • kevin64
          • 170
          have you tryed to flash thought your web browers are you shore you have 72 bl install with 2.0 sim Digital Kaos - Downloads - how to flash a dreambox 800 with web browser
          • southpaw
            • 2233
            Hi Sapcoms .i wasn`t gettin the error pop up in dreamup (as per readme file with fix) what i did was 1st part of repair with dreamup , box display then reads somethin like http mode with address 192.168.2.24 , i took this address to my browser and then flashed thru browser a new image , worked a treat , good luck mate
            • sapcons
              • Sep 2009
              • 15
              Kevin:
              the box doesn't show an IP. The box starts and shows immediately the error. I scanned the network with DCC, but no box was found.
              southpaw:
              was this an old entry in DreamUp or how did you find the IP?
              • Nucleard
                • Feb 2010
                Ill try this!
                • sapcons
                  • Sep 2009
                  • 15
                  I have also removed the tuner, but this box still doesn't boot.
                  • kevin64
                    • 170
                    have a look at this post m8 http://www.digital-kaos.co.uk/forums...problem-90895/
                    • sapcons
                      • Sep 2009
                      • 15
                      I tried all Dreamup versions with all different possibilities to force the flash button. Nothing works.
                      the Remote IP is not accessible. Dreamup always says 'File to big".
                      • southpaw
                        • 2233
                        i used this one
                        Digital Kaos - Downloads - 2nd stage and force flash
                        instructions state
                        Now for the second sollution
                        1) Connect broken dreambox DM600/DM800
                        2) Open dreamup, press connect.
                        3) When you see second loader error popup, just press ok.
                        4) Open http://www.gsmsweden.com/forhike/sat...stage_pack.rar
                        5) Drag DM800_repair in front of dreamup, and press dream multimedia logo.
                        6) Now press the greyed Flash button, and chose firmware.
                        7) The flash progress will probably hang, its OK.
                        8) Open dreamup again, connect the broken box, press connect.
                        9) If all went ok, you can now flash box again, (Use only serial
                        communication)
                        I only got as far as step 3 , and dreambox display then showed " http mode 192.168.2.24"
                        entered this addy into browser and uploaded as per normal routine
                        • sapcons
                          • Sep 2009
                          • 15
                          Southpaw:
                          3) When you see second loader error popup, just press ok. ---> The error message never comes up. The error is only displayed on the box
                          • southpaw
                            • 2233
                            same as me (no error pop up), however at step 3 somethin loaded in dreamup ,and display did change to http mode ,
                            Are you powering box up at correct time , after step 2 ?
                            • sapcons
                              • Sep 2009
                              • 15
                              --> PC to DM via cable, right? Is it necessary to connect both (PC and DM) to the LAN?
                              --> insert power cable, right? How about the LAN settings? Anything required here (tick the box, put in IPs?)
