Choppy picture on Sky Sports 1 HD
  • MikeTV
    • 8
    Hi guys,
    Sly sports 1 HD is coming through choppy and pixalated on my DM800. This is also true for Sky Real Lives HD & Channel 4 HD which are coincidently on the same transponder.
    The ecm seems fine (<0.300 secs).
    Is anyone else experiencing problems, or can help me out?
  • bubbles69
    • Feb 2010
    • 1155
    very common dm800 need strong signal if not they glitch normally on
    discovery hd
    disney cin hd
    sci fi hd
    sky sports 1
    i notice once the snr ate on discovery hd is 71% i had no problems
    • MikeTV
      • 8
      Thanks for the swift reply.
      I've got a fairly long cable run which doesn't help, but the affected services are showing 83% snr, with others showing 72% and giving a strong reception, so a bit strange.
      Are the in-line amplifiers effective for this problem?
      • smirnoff_rules
        • 8603
        l have more problems with discovery channels than everything else no idea why , but if u have a busy house ie kids on lappys and so on that dosnt help
        • MikeTV
          • 8
          discovery hd
          disney cin hd
          sci fi hd
          sky sports 1
          Yeah, same problem here with those services as well.
          i'm going to buy one of those in-line amps tomorrow to see if that makes a difference.
          • davvo
            • Apr 2009
            • 666
            can confirm this one works
            no glitching and all sats switch no loss of any channels
            just over 3 quid
            In-Line Signal Amplifier Sky Satellite Booster + 2F's on eBay (end time 14-Apr-10 10:33:06 BST)
            • nilrem
              • 54
              Are these clone boxes ?
              Been reading anf found there is a common problem on these where HD channels don't clear properly until the tuner has warmed up.
              There is a mod being done
              Stolen from another source
              For faulty Rev. K tuner remove capacitor C1 and insert a 1000UF (16V) capacitor at the marked points (details you'll find in the pictures)!
              • dranny69
                • 22
                just over 3 quid
                thanks for the link just bought one! one question, can you just plug the out end straight into the dreambox or do you need to split the cable to get best results ?
                • davvo
                  • Apr 2009
                  • 666
                  you need to make one of these or buy one
                  • rruunneerr
                    • 62
                    Hi all,
                    to second the question above can these be fitted straight into the back of the dreambox or are better results achieved by splitting the cable, if so where?
                    Thanks in advance.
                    Kev.
                    • davvo
                      • Apr 2009
                      • 666
                      you cant plug it straight into the back of the dreambox
                      it wont fit as it has the same fitting
                      you need a short cable about 10inch with 2 f-plugs on
                      fit the short cable to the dreambox and the amp to the other end
                      see the pic
