best image
  • damiensk
    • Apr 2010
    • 201
    best image
    have just got my dm 800s cl, bl 75 sim 2.01 its got gemini 4.60 on already,
    but was wondering is there a more stable image or is that ok?
    have a 500 at the mo, with a pli jade image on, which i kinda like.
    read a few threads, and 4.70 gemini, gets a bit of a thumbs up, for the hd channels.
    i have a 1.0 mtr dish,
    do it now before i set up everything,
    so do i stick or change,
    thanks in advance
  • bubbles69
    • Feb 2010
    • 1150
    gemini 4.70 is good and more stable if you use a smaller dish, with a big dish you prob not have to worrie and nabilosat 0.12 is best for EPG downloading etc.
    also make sure you flash the correct images from here..
    • deffc0n
      • Aug 2009
      • 894
      Gemini is the best
      • westkill
        • 2378
        personally i would go for the nabilosat image
        • Oily
          • Apr 2009
          • 123
          Personally I'd go for the DreamElite image,a tad better than the Nab BH12
          • bubbles69
            • Feb 2010
            • 1150
            does that image have the EPG satmate download feature like nabilosat?
            • Oily
              • Apr 2009
              • 123
              Yes it does,just go to the add ons manager,then Enigma 2 settings then d/l the updated EPG provider config list V3 then it shows up on the EPG lists you can d/l
              • damiensk
                • Apr 2010
                • 201
                want to be able to use the epg,
                so dreamelite or nabilosat image?
                presume gemini image not good for epg?
                never d/l epg, on to a box.
                never bothered with my 500, but would like to with the 800 hd, is it easy to do?
                thanks in advance
                • Oily
                  • Apr 2009
                  • 123
                  It's easy mate,if you get stuck,just ask
                  • damiensk
                    • Apr 2010
                    • 201
                    couple of questions,
                    dm800 bl75 with gem 4.7, 1m dish,
                    but dish is 100 foot away in back garden
                    struggles a bit on hd s*y channels, snr about 65%.
                    ok on itv1 hd etc, snr up to 80s,
                    was thinking of putting a in-line amplifier on, would that help?
                    also epg help, i know gem 4.7 isnt the best for it, but how do i get it, d/l it?? or something else?
                    thanks in advance
                    • Oily
                      • Apr 2009
                      • 123
                      You could try it but sometimes it won't fix it but for only ?3 your not losing much if it didn't work.
                      Maybe try CrossEPG
                      CrossEPG
                      • placi76
                        • 5
                        gemini 4,7 the best for me
                        • placi76
                          • 5
                          or gemini 4,6
                          • CG121
                            • Apr 2010
                            • 62
                            thanks in advance
                            If you can't get an Astra2 signal from a 1m dish in the UK, then there's something wrong with your setup...
                            The fact you've got 100ft of cable is of no significant importance as long as you've used high quality double screened cable and your LNB isn't ~~~~ed...
                            Using an inline amp is more than likely to introduce more noise..
                            • damiensk
                              • Apr 2010
                              • 201
                              kaos.co.uk/forums/downloads/images/2/dream-elite-clone-bl-72-1101/
                              can i use the above image for my dm 800 hd cl, with bl 75,
                              even though the above is bl72?
                              would it be better for epg, and better for hd channels?
                              I am running on a gem 4.70 at the momment.
                              or anybody point me to a link for something better!!!
