file to big not fixed
  • abualferas
    • May 2010
    • 18
    #31
    johnleo just keep doing that eventually the dreamup will respond and flash with dreamup I have dm800 bootloader 75 sim 2.01
    • abualferas
      • May 2010
      • 18
      #32
      THE FIX
      U need to use hyperterminal
      connect to dreambox
      after connection press s it will take u to the bios change dhcp to manual then write the ip you want
      then exit the hyperterminal with saving
      power off the box then power it again while pressing the silver buttom in the front
      use that ip to flash the image for ur box
      • nabets
        • Mar 2010
        • 13
        #33
        Hi, is anyone got Dreambox Second Stage Loader BUILD #59, built 20080509 file?
        • greekfragma
          • 16
          #34
          Hello guys. I have been reading you for a long time and found many useful things but now I will really appreciate some help.
          I have a clone dm800hd with bootloader 72 and sim version 2.01 and was using the Gemini 4.5 for the last year.
          Unfortunately I was not reading the latest news on images and flashed my clone with the gemini 5.1 which apparently had the wrong bootloader version.
          I came across the classic ''no ca found'' after flashing through web interface so i tried dreamup with null serial cable.
          Tried 1.3.3.2 , 1.3.3.5 and 2.0.0.9b versions. I also tried the dm800repair.exe patch by forhike and natas with no success.....
          On a normal boot the clone says ''error no ca found''
          On serial boot I am stuck at Dream Multimedia logo and Dreamup says '' is not a valid integer value''.
          I press ok and try to flash with patch but all 10 different images i tried all come with FILE TO BIG error.
          What am I doing wrong?
          p.s. I found the ipk second bootloader file but I really dont know what to do next. Please enlighten me.
          Thanks in advance.
          • artic
            You have to use a special Dreamup to get the image in and u need to use a image patched with the right bootloader (72), or, load original non-patched image first, then without resetting box, load correct bootloader 72 and reboot. You will find the "dreamup 2009 patched.exe" in the file named "2nd_stage_pack". u can pm me for the file, if u don't find it-
            • deffc0n
              • Aug 2009
              • 894
              #36
              Thanks in advance.
              This is normal never fix FILE TO BIG because you not connect Dreamup with DM800.
              Check always button connect when you have File to big you have disconnect.
              • greekfragma
                • 16
                #37
                ok...so i open dreamup patched.exe and i leave dreambox only with serial (null) cable (tried 2 different cables) .
                When dreamup finds dm800 on log window it throws an error.
                [ '' is not a valid integer value ]
                so the difference is that i do not manage to get to the 2nd stage bootloader error......Even with enforcer that enables flash button i get file to big problem with all images (bootloader 72 or earlier no difference) and with also 2nd stage pack.
                please help
                • greekfragma
                  • 16
                  #38
                  for all to know about my problem.......obviously the cable was fine but there was some kind of incompatibility with the com1 port of the laptop i was using.
                  I managed to save my clone and make it functional again by connecting usb to serial cable with this driver
                  _IO Cable_PL-2303_Drivers - Generic_Windows_allinone_PL2303_Prolific_DriverIns taller_v130
                  from this site
                  ?????????? PL2303 Prolific Driver - Mobile Files.ru
                  I just used dreamup to wake up the clone and then i just flashed through web interface because clone got a dhcp ip.
                  • panamar
                    my dreambox dm800hd pvr was running on green jade image the box did a software update now the box is saying dream multimedia error 1 no ca found please help me new to this box help me fix this error step by step thankyou
                    • sale12
                      • Sep 2009
                      • 56
                      #40
                      Read this mate
                      • mikulas975
                        • Nov 2014
                        I am searching it too ...
                        • WOODWARD395
                          • Apr 2010
                          • 628
                          #42
                          look very simple try these files follow pdf file to the letter should resolve your issues.
                          you need drag icon across dream up patched then click and it will work trust me.
                          DreamUP_Patched_dm800_clon.zip
                          Education is not the learning of facts, But the training of the mind to think
                          So hit the thanks button if I have enlightened you.
