Dreambox 800 clone problem
  • malcjj
    • 10
    I really hope someone can help me with this problem as im really stuck now and possibly out of pocket.
    I bought 3 x 800 clone dreamboxes from china of which 2 were definetly bootloader 75 but im not sure about the third one, anyway to cut along story short i flashed two of them with sim201e-75-Dream-Elite Black Hole_13-OE1.6 and everything is ok but the third one is now just saying dream multimedia on the display and nothing else.
    I can only connect to it using dreamup via serial cable and obviously this takes over an hour.
    I have contacted the supplier and they have told me they should all be bootloader 75 but it is possible it could have been 72.
    is there any way to fix this now as i tried to flash it but its still the same..
    Is there any way i can find out the bootloader?
  • westkill
    • 2378
    try flashing an image with bootloader 72
    Digital Kaos - Downloads - Nabilosat Enigma2 Black Hole - DM800 v0.12 FOR CLO
    or
    just the bootloader
    • malcjj
      • 10
      hi thanks for the reply i have tried that image but it is still the same. How do i flash just the bootloader and am i likely to damage the box completely by keep flashing it?
      • malcjj
        • 10
        forget that i have just found how to flash the bootloader. Will i damage the box further by flashing the wrong loader?
        • southpaw
          • 2233
          try forcing flash with dreamup , same procedure as fault "c a error"
          some pointers in this thread mate
          • westkill
            • 2378
            try this it,s a second stage bootloader 72 with nfi extension
            try flash this with dreamup
            then the image after
            • malcjj
              • 10
              ok thanks for all your help i will give it ago, but what happens if it was bootloader 75 will this kill the box.
              Also it doesn't come up with any errors just says dream multimedia.
              • westkill
                • 2378
                if it suposed to be bootloader 75 sim
                any older ones are ok to flash
                • malcjj
                  • 10
                  ok that all makes sense now thanks again and hopefully i will be able to sort it now..
                  • malcjj
                    • 10
                    no its still the same. Do you have any other suggestions please?
                    • .: JaCkPoT :.
                      Retired Sat TV Addict
                      • 5607
                      For accademical reasons i make this post.
                      If you were to flash a image which is for an above bootloader, i simple reflash of the correct image using DreamUp will resolve all problems.
                      ___________________
                      In the good old days, I had
                      DM800s HD
                      Openbox S10
                      TM500
                      DM500s
                      90cm FortecStar dish
                      Maxx 110cm Dish
                      Technomate 2300 Motors
                      • malcjj
                        • 10
                        finally fixed it it was 72 after all but it has taken 6 flashes to finally get it working, i appreciate the replies and the helpful advice thanks
                        • .: JaCkPoT :.
                          • 5607
                          This How to find out What your second stage bootloader is.
                          Telnet to your box.
                          Login
                          Then type this.
                          'ipkg list'
                          Now scroll up to results for d. Here you will see something like this.
                          Dreambox secondstage And the bootloader will be there.
                          ___________________
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          Maxx 110cm Dish
                          • westkill
                            • 2378
                            like this in detail
                            • fandjo
                              hello my friend have problem with dm 800 clone
                              No CA found by 2nd stage loader, please contact support at dream-multimedia!
                              what i kann to do now
