dreamelite 1.3
  • arrod-ball
    • 33
    #16
    Originally posted by bubbles69
    maybe you overwrite the bootloader when flashing with a image if you bought box as bl76 gemini 5.0 it must be does it have gold sticker with sim 2.01 underneath and did it say latest l3 tuner when you purchased if so you def overwrite the bootloader you must use patched images for you box version
    bubbles69 it has the gold sticker sim 2.01 but only K3 tuner. is it possible to get back to bl76 is there any advantage by having the latest BL or stick with bl72?
    • bubbles69
      • Feb 2010
      • 1150
      #17
      If it has k3 tuner from factory, there is not way it was bl76 where did you get it from?
      • arrod-ball
        • 33
        #18
        I bought it from China. better not say exactly where but this was in the opening line of the advert 76 BOOTLOADER SIM2.01 as i say i have checked the sim it is deffo 2.01 with K tuner
        • bubbles69
          • Feb 2010
          • 1150
          #19
          Sorry to say m8 the internals are outdated New version dm800 comes with L3 tuner and and BL76 Gemini 5 you must contact seller for replacement.
          • arrod-ball
            • 33
            #20
            I would think i have more chance of winning the lottery than getting a replacement. You pays your money you takes your chance i suppose. It was the cheapest i could find on the net so it serves me right.
            I must admit that during our post the more i am thinking about it it does explain why i was having trouble loading some of the newer images. I suppose as its up and running i will use it for a bit then look to upgrade to a newer verison if i can't live with the nabilo image not that there is anything wrong with the image.
            Thanks for your help anyway.
            • bubbles69
              • Feb 2010
              • 1150
              #21
              shame m8, this is problem with china its so expensive to return things..! yes there is a dreamelite patched for bl72 you can use..!
              • davvo
                • Apr 2009
                • 666
                #22
                if you flash dreamelite 1.3.3 and BL70
                on page 1 of this thread
                then telnet with this command
                ipkg list | grep second
                it will tell you that you have BL76
                • arrod-ball
                  • 33
                  #23
                  davvo, excuse my ignorance but what will this achive. Will it just confirm that i was sold a lesser spec DM or will it give me bl76.
                  Cheers
                  AB
                  • davvo
                    • Apr 2009
                    • 666
                    #24
                    nothing wrong with your dm
                    i take it you want dreamelite 1.3.3
                    and you have BL72
                    then install whats on page 1
                    with this img BL70 BL72 BL76 all works the same
                    your not missing out on anything
                    • arrod-ball
                      • 33
                      #25
                      and you have BL72
                      Cheers davvo i think your right i would like to try dreamlite 1.3.3 thats how this thread started. one last question if i may do i have to use Dreamup or can i quick flash by putting the ip addy into mozilla. thanks for your help.
                      AB
                      • davvo
                        • Apr 2009
                        • 666
                        #26
                        you need to use dreamup
                        tick use network takes 2 mins
                        dont reboot
                        then flash BL70
                        cuz if you use mozilla you will lose ip for 2nd flash
                        • arrod-ball
                          • 33
                          #27
                          ok i will try that tommorow.
                          • arrod-ball
                            • 33
                            #28
                            davvo, will it only take two mins if i use RS232 if so thats why i dont like using dream up. in the past RS connection takes ages.
                            • davvo
                              • Apr 2009
                              • 666
                              #29
                              use both null modem and network cables
                              tick use network
                              null modem cable will just id the box
                              it will take 2 mins
                              the reason you have to use dreamup is
                              you need to flash the BL70
                              without rebooting the dm800
                              dreamup will keep the ip that it is using alive
                              • southpaw
                                • 2233
                                #30
                                it is possible to upgrade bl 72 to 76 on sim 2.01 , i am running 76 now , and was 72 when purchased in November,
                                think i upgraded from 72 to 75 using a blackhole image , will double check and reply later
