Dreambox 800 from Yaouxin
  • rapscallion
    • 141
    I see it already has a gemini. I have an eagle. I am thinking of doing a straight swap. I take it I dont need to put a new image on it. I will have to set the network up,How do you do this?
    Once usals and the network are set up. I take it i need a ccm and cfg file.That will be in the addons Right??
    Do I use dreamset 2.29 to send a channel list to the box.
    Any other tips to get started greatly appreciated
  • on_the_jazz
    • 557
    You can do a flash just to make sure you know what's on there. Network is under network settings like most images, and yes you'll probably have to use add-on server to get cams. Use dreamboxedit for bouquets.
    • yamar1
      • 970
      flash it with blackhole, the best image around for this box.
      Faster than Faster
      • andy91
        • 3583
        You got some reading to do mate its not as simple as that but one step at a time and reflashing with a good image like black hole.
        Thats the one im using as well and can recommend.
        As for setting up your network you will need to find the ip of your router and add that but if you can find a good guide have a read first.
        Andy.
        • rapscallion
          • 141
          Cheers lads. Is there any major advantage of the blackhole ove the gemini 5.0 image?
          Can I use this
          • norman22
            • Jul 2010
            • 12
            yes but you need to flash the patched bootloader afterwards
            • rapscallion
              • 141
              Thanks. Is that 76 to 76a?
              • jumpinjo
                • 869
                here's image and patch
                • rapscallion
                  • 141
                  Originally posted by jumpinjo
                  Fantastic. Thank you very much to all.
                  • rapscallion
                    • 141
                    Got it working without much fuss, Thank you all, Just one more question about Blackhole. How do you delete channels with the RC
                    • .: JaCkPoT :.
                      Retired Sat TV Addict
                      • 5607
                      dreamboxedit
                      ___________________
                      In the good old days, I had
                      DM800s HD
                      Openbox S10
                      TM500
                      DM500s
                      90cm FortecStar dish
                      Maxx 110cm Dish
                      Technomate 2300 Motors
                      • rapscallion
                        • 141
                        Thanks I was using dreamset. It sent the settings ok but when I tried deleting a few, it never deleted the channels whem I sent it back to the box
                        I'll try dreambox edit instead
