hi guys whats happnig is evertime a new program starts the info bar comes up is there away to stop this. im running blackhole v12 on dm800 tx
hello mate if it is same is mine you should go to
Menu
Setup
System
Customize
First one should say Setup Mode
change setup mode to Expert
half way down it says
Show infobar on event change and should say yes next to it
just change that yes to No then press ok
You should be sorted
