Jitter on only a couple HD channels
I don't really think it is just down to signal strength, reason for this is I have a 1.2m and a minidish, when I set my system up I connected the DM800 to the mini dish and it glitched, installed an in-line sloping amp and sorted, but:
Messing about the other day I started getting glitching with the in-line and also when connected to the big dish, was doing my head in, and as the DM800 wasn't moving my dish I changed out the PSU for the one of my DM600 12v 3amp, glitching stopped straight away.
Now could it be that it stopped due to a reboot of box, or is the crappy PSU that comes with the DM800 to blame....
SpComment
Similar DM as yours, but cannot open HD channels ?
What shall I have to modify on the config(tuner or //)
Thanks for your guidance.
kadnorComment
Tried experimenting with the length of cable required to add the in-line amp. When I introduced a longer cable (2 feet) the glitching was re-introduced. I then tried a shorter cable (8 cm between DM800 and in-line amp) and this has removed glitching across all channels. ESPN, Syfy and Disney HD all working as intended.
I have the same exact problems as yours (same channels) and did the same things you did (in line amp 8 cm away), but with dramatic different results: signal is totally gone on those troubled channels (SNR=0), the amp is attenuating the signal instead of amplifying it!!! What's happening?Comment
