Newbie Dreambox800
  • waj_uk
    • 175
    Newbie Dreambox800
    Hi, i have just purchased a clone Dm800, i need a bit of guiding as i couldnt find anything in the threads i looked at.
    The dm800 is flashed with Gemini Enigma 2( if that make sense) and has ccCam 2.14 installled.
    I have a normal sky dish and have done a scan for Astra 28.e and it has only come up with a few channels? and i can only view bbc news at the moment! i ideally want to see all the channels available from that satellite, i know i wont be able to view the encypted channels but i just want to be able to have them showing up as i intend to connect my box to the internet
    what am i doin wrong??
  • opsmonkey
    • 5379
    Astra is at 28.2E.. what was it listed as exactly when you selected Astra
    sounds like a corrupt satellites.xml file to me
    • waj_uk
      • 175
      sorry thats what i meant 28.2e i am going to give it another go now and see what happens
      • waj_uk
        • 175
        ok i think i got them now i was doing a automatic search before and now i have done a satellite scan search thingy and it has found 800 odd channels on 28.2e is this about right?, So what do i do next i have broadband and have just purchased some homeplugs??
        i have one of those crappy space saver computers so i dont have a serial port on it..how do i connect my broadband to the box etcc
        thanks in advance for all your help
        • opsmonkey
          • 5379
          all the answers you need are here mate just search..
          connect router to home plug then other home plug to dreambox, you dont need to connect your box to your pc by null modem unless you are flashing it, you can connect to your box via your pc over your LAN
          • waj_uk
            • 175
            ok homeplugs are in, what do i do next STUCK!,
            also am i using the right cam i've got these options
            Common interface
            CCcam 2.1.4
            CCcam 2.1.4/OSCam
            CCcam 2.1.4/NewCs 1.67
            Whats the difference and what do they do?
            I have no idea what i should be doing after this, i am still getting just FTA, can i open anything with just the Cams or do i have to C/S? I'v read about editing certain options etc but dont have a clue how to do it
            also any guidance on sky bouquets how i can get the channel list sorted, im assuming my box is connected now via the router
            Thanks for your continued help
            • waj_uk
              • 175
              opsmonkey, where are you based?, i am in staffordshire as i may need to hire your expert knowledge!?
              • opsmonkey
                • 5379
                select CCcam 2.1.4/NewCs 1.67, you wont decrypt anything without CS
