hd channels glitching
  • standarren
    • 857
    hi guys a have a 90 cm motorised dish with a dm800hd with cccam installed i can pick up all sats but i'm experiencing glitching on hd channels every few minutes my snr is 84agc 99 ber 0
    this is the box
    DM800HD (S) (NEW VERSION DM800PRO) SATELLITE RECEIVER LATEST TUNER REV (M) - ukdreamshop
  • opsmonkey
    • 5379
    all HD channels..???
    • standarren
      • 857
      some hd channels seem ok are some hd channels harder to get than others i have noticed that the snr changes on different channels
      all on sky uk
      • mark8393
        • 2305
        all on sky uk
        looks like an inline amp is needed.
        • opsmonkey
          • 5379
          not on these new boxes..
          all on sky uk good or bad..??
          may need to look at where your sky comes from mate too
          • standarren
            • 857
            some hd channels are at 100% the lowest at 80% it seems the lowest snr is when i get the glitch
            thanks for your help do you think the in line amp will work
            also would you recomend a nice new lnb
            • opsmonkey
              • 5379
              what channels are causing the problem..?
              these new boxes don't need an inline amp
              • standarren
                • 857
                5 hd is 84snr
                • opsmonkey
                  • 5379
                  just 5HD..??
                  if its just 5HD then its not the box.. maybe your dish needs a little tweak..
                  • BlueBox
                    • 573
                    let us know how you get on
                    DreamBox 500HD NewEnigma2
                    • standarren
                      • 857
                      i did align the dish the other day could it be a skew lnb
                      • cris808
                        • 133
                        Are you on a CS? Check your ECM times.
                        Otherwise as others have suggested try tweaking the dish and lnb.
                        SNR doesn't need to be really high to have a better picture. You could have 34% snr and have a great picture.
                        • standarren
                          • 857
                          ecm times are nice and low
                          • father ted
                            • Feb 2008
                            • 1389
                            it could just be the bad weather m8
                            • bubbles69
                              • Feb 2010
                              • 1150
                              Yer I would say ECM or bad weather most of my hd channels are 100% snr I have the same box dm800pro with no problems at all, if you getting snr of 100% you must have the pro version also
                              Also what is your ECM at time of glitch you must check this
