Ups, I have never tried this before, hope I can find out how to do it. And I don?t think my supplier of C-lines will accept sharing even if I have payed for 2 lines. My idea was to take the mac-adress from the DM500 and put it in the DM800 no2, but I don?t know how to do it???
That might be the problem, your wireless access point, or router, may have MAC security set up to ensure that only devices with the MAC address in your rules can connect. If the MAC addresses on the DM800's are the same then they will both be unable to connect at the same time, even if you set up different IP addresses, it depends how your router or access point feels about it.
try set your DM800 No. 2 to
IP Address 192.168.2.10
Netmask 255.255.255.0
Router Address 192.168.2.1
Primary DNS 192.168.2.1
Second DNS 194.239.134.83
As mentioned it might be your wireless that is secured by MAC address. If that is the case you may need to change the configuration of your router, probably under a section called access control which will contain the MAC addresses of your DM800 No.1 and DM500S.
And now for those non English people...
Er du bruger tr?dl?s?
Der kan v?re problemet, dit tr?dl?se adgangspunkt eller router, kan have MAC sikkerhed sat op til at sikre, at kun enheder med MAC-adresse i dine regler kan oprette forbindelse. Hvis MAC-adresser p? DM800's er den samme, s? vil de begge v?re i stand til at oprette forbindelse p? samme tid, selvom du oprette forskellige IP-adresser, det afh?nger af, hvordan din router eller access point mener om det.
Pr?v indstille din DM800 nr. 2 til
IP-adresse 192.168.2.10
Router adresse 192.168.2.1
Prim?r DNS 192.168.2.1
Anden DNS 194.239.134.83
Som n?vnt kan det v?re dit tr?dl?se, der er sikret ved MAC-adresse. Hvis det er tilf?ldet kan det v?re n?dvendigt at ?ndre konfigurationen af din router, sandsynligvis under et afsnit kaldet adgang kontrol, der vil indeholde de MAC-adresser i din DM800 No.1 og DM500S.
Hvad m?rke og model er dit adgangspunkt og router?
Exactly, this is the problem (I am danish). My router is a DELL Truemobile 2300. My problem is that I am not a specialist in router. Everytime I try to fix a problem with a router I always destroy more than I fix.
Damned, I think I got it to work with method no2 after I changed manually the ip adress on receiver no2 and set DHCP to "off" on no2 receiver. For the moment they both works perfect. Let us hope it will continue. Thanks to all which helped me.
