Should fan be plugged in?
  • jaipal2004
    • 25
    On a DM800 clone without hard-drive - should the fan be plugged in? Had a unit where it wasn't and then I plugged it in.
    Just wondered what the case was?
  • The fat man
    • 196
    You should plug the fan in as the unit will get very hot without it and possibly fail
    • jaipal2004
      • 25
      ok - I've plugged it in but now it's constantly on - is there some software/plugin that only makes it kick in when it needs to?
      • The fat man
        • 196
        sorry im am not sure but my mates is on all the time aswell
        • kadnor
          • 78
          I hope you have placed the FAN and screwed on top of the processor chip.
          Long hours of use may show the tuner unit becoming warmer when you touch with your fingers, a note book cooler unit is available on the market.This is a great help.
          To note that countries near the equator ( 25* up or down) ,it is normal to experience
          a bit of"heat" around processor and tuner unit.
          Hope this will help.
          CHEERS
          • jaipal2004
            • 25
            yep - the fan sits on the CPU. The heatsink is slightly off one corner but as its glued on I can't change it now
            I had hoped the fan would cure the issue I was getting with the box not showing via DVI/HDMI at random times (although working on SCART) but the problem has returned today. I think it might be my LG TV!!
            • Damo1888
              • 56
              Has anyone had their DM800 fail because of having the fan disconnected without a hard drive?
              • kaisar1
                • Aug 2009
                • 462
                Hi I bought a cheap USB fan from eBay. Do I place the fan underneath the dreambox or on top?
                Sent from my HTC Desire using Tapatalk
                • yiakas
                  • May 2011
                  • 7
                  i have my USB fan underneath and cools good.
                  • southpaw
                    • 2233
                    After testing Best method I found for external fan was sitting on top , also check which way round it is as one side will suck and the other will blow , best to have the fan exhausting the heat , therefore the suck side needs to be flat against the dreambox sitting on top of as it's easier to push the hot air away than if it was trapped underneath
                    • lombard
                      • Aug 2008
                      • 793
                      just put the fan on top of box, air blowing into the air vents, i find this much better,
                      I find this does the job well, dont need 2 fans, makes more noise, this cools it great and cant hear it at all, and you can snap off the blue led if dont like it
                      http://www.ebay.co.uk/itm/2306404254...84.m1423.l2649
                      • dctyper
                        • 2539
                        the box runs fine without a fan, early models didnt have one.
                        dc
                        Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
                        previous life dm800hd and 500c on cable screw you nag3
                        • lombard
                          • Aug 2008
                          • 793
                          [QUOTE=dctyper;1220735]the box runs fine without a fan, early models didnt have one.
                          just wondering do the clones run hotter then the originals, cause we know they didnt have a fan, clones do seem to run hot, wondering how they compare to a original ?
                          • andy211081
                            • 575
                            Get a dm800se as the built in fan is cool cool cool! I sit my beers on top to keep them cold ;-)
                            Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
