No CA found - Can't reflash with null-modem
  • southpaw83
    • 360
    #16
    No CA Error can be fixed by flashing with Dreamup v1.3.3.4 using null modem and Ethernet cable at the same time.
    • glorytee
      • 20
      #17
      thanks for your respond lincsat,i try to dreamup the box also with working clone box but still getting thesame message.i don't mind if u can send me a link to the wright image to flash,my box is using 2.01 76bl,thanks
      • andy91
        • Aug 2010
        • 3583
        #18
        First you have to get the box to respond using Dreamup,thats the hardest part.
        Perserverence is the key but it will respond eventually but trying different versions of Dreamup and the patched versions might do the trick.
        You can use any sim2 image for your box bt the Dreamelite Phoenix Edition is a firm favourite with most,you can find it in downloads.
        Andy.
        • glorytee
          • 20
          #19
          Thanks a lot 'andy91'i will continue give a try with the dreamup
          • glorytee
            • 20
            #20
            pls if i get u well,i should use either of the 2? i.e null cable or Ethernet cable?
            • andy91
              • Aug 2010
              • 3583
              #21
              You will definately need to use the null modem cable but sometimes you can add the ethernet as well it will speed up the flashing.
              Ive tried it with both and have the Use Network box ticked and unticked to get it to respond,its just trial and error.
              aNDY.
              • glorytee
                • 20
                #22
                Thanks but check this post southpaw83
                Uploads: 0
                • glorytee
                  • 20
                  #23
                  box alive atlast
                  hi andy91,
                  thanks for your help and encouragement here,i got my box working atlast after all this sufferness.
                  • glorytee
                    • 20
                    #24
                    very soon i will share how i did it here,it unbelievable
                    • glorytee
                      • 20
                      #25
                      ho my God! there is nothing to share as my box can not reboot any more,it can flash image successfully but it can reboot,please i need help,is my box dead or the sim?
                      • andy91
                        • Aug 2010
                        • 3583
                        #26
                        Has the image loaded or not?
                        Andy.
                        • glorytee
                          • 20
                          #27
                          hi andy,
                          The box can load any compartable image at anytime but it can not flash please what can i do?is the sim currupt
