No CA Error can be fixed by flashing with Dreamup v1.3.3.4 using null modem and Ethernet cable at the same time.
No CA found - Can't reflash with null-modem
First you have to get the box to respond using Dreamup,thats the hardest part.
Perserverence is the key but it will respond eventually but trying different versions of Dreamup and the patched versions might do the trick.
You can use any sim2 image for your box bt the Dreamelite Phoenix Edition is a firm favourite with most,you can find it in downloads.
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
You will definately need to use the null modem cable but sometimes you can add the ethernet as well it will speed up the flashing.
Ive tried it with both and have the Use Network box ticked and unticked to get it to respond,its just trial and error.
aNDY.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Thanks but check this post southpaw83
Uploads: 0
No CA Error can be fixed by flashing with Dreamup v1.3.3.4 using null modem and Ethernet cable at the same time.Comment
