hi all, i need some help, info. just bought a technomate 5402hd and been using it for nearly a week, when i was watching channels it was scrambling every now and again bot the line was connected
anyway to cut a very long story short, i went into the setting on my virgin media router and found that evertime the channel scrambled i was getting a DHCP failed error which would explain why this was happening.
i sought some advice and was told to turn off DHCP on the technomate and input manually the ip setting etc
there is a problem here because i cannot enter a single digit
for example if i need to enter 192.189.1.0
i cannot do the single digits i can only do 100.000 on the single digits
anyway i dont even know if this will be a fix for the dhcp error
has anyone else had a similar problem?
this only happens on technomate
i have been using ethernet on starview and kryptview and never had the same problem.
does anyone know how to sort this?
is it bad packets been senf from my line?
any info would be good
