TM-5402 HD only"----" lines
  • elsaadore
    • Sep 2012
    Hello ppl I have Tm-5402 hd I don`t understand it doesn`t come on on box display i can see after flashing red led then "----" lines
    i tried factory default but same:S
    Any one can help what need to do ?
  • thijs
    • Apr 2010
    • 1096
    send back to supplier and get different box
    Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
    • happy_highlander
      • Aug 2010
      • 3535
      Have you put any firmware on it....can't remember if mine came with firmware or if I had to put original on before scanning for fta
      • elsaadore
        • Sep 2012
        I did not put any software I tried from rs232 the original software but nothing change :S
        • happy_highlander
          • Aug 2010
          • 3535
          You don't use rs232 on 5402 put the original software on a usb then plug it in and select data transfer from the usb menu and select the original firmware
