i have a 500gb external hard drive in ntfs format. when i try to format it on the technomate using disk manager it fails? any help would be appreciated
Technomate 5402 recording?
i tried that & my box then recognises it & when i set a programme to record it says on the timer it will record but it never actually does. for example i set wwe raw to record at 1am & the next day when i checked it wasnt on the file list at all...Comment
It needs to be fat32 or it will defo not work.
what patch are you on.
Patch 126 has a pvr bug if on 126 try 127 here Download center
Make sure when patching to backup channel list and do factory reset before and after patch and put back channellist and rescan.Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
im on patch 127. im back on fat32 using my laptop now & im gonna try recording something again tonight. whenever i wake up in the morning theres nothing in the file list even though i left several things to record & it says "check usb" in the morning sometimes too.It needs to be fat32 or it will defo not work.
Make sure when patching to backup channel list and do factory reset before and after patch and put back channellist and rescan.Comment
In the disk manager menu did you try the test function
Is your EXt. HDD of good speed.
When you connect it back to your tm make sure to go into the disk manager menu and when you leave that menu save the changes even if you did not change anything this will mount your HDDEverything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
I did that and it says the speed is bad?Comment
I use an iomega 1TB usb powert HDD with very little problems should be around the same price.
Some HDD work and some don'tbut this is with all stb'sEverything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
